When you install the aftermarket iac sensors you need to have the pintle out 1in to 1 1/4 in from the base. Did you do this? If you did it sounds like you need to turn your idle screw up a bit more. THe idle is in the chip so it is going to idle there no matter what. THe idle blade screw is used to set the iac for idle.
