corsair231
- Jul 8, 2005
I have a problem starting that I need help narrowing down. My car is a pretty mild build. Te-60, 42's, 3" thdp, pac alky, stock suspension, stock d-5 and a stock 2004r that has a B&M transpak shift improver kit.
Normally when I roll on to the throttle fairly agressively from a second gear start the car will break traction and then grab and start pulling thru the top of the rpm range. You can tell by the rear end twitch and the speedometer bounce. :smile: Lately though, especially on cold mornings when it feels like the car is making good power, the car has started acting differently sometimes. It feels like the car is not pulling like it should. The car starts off just like it has broken traction but the speedometer doesn't jump like it would with tire spin. The rpms jump to redline almost immediately and hold. Ease off of the throttle a little bit, rpms drop and everything returns to normal. I guess something is starting to go but I'm not sure what it is. How do you determine if the slippage is in the trans or in the converter?
TIA
TIA
