carlsbadGN
- Aug 31, 2004
Not sure whether to post here or in the smog forum but here goes. I’m due for a smog certification in southern Cali. Removed or disconnected all the alcohol related items and returned the vehicle to stock condition, with the exception of the air intake, adjustable FP regulator, and TT emissions chip.
While driving in city traffic to the testing facility, I noticed the car would bog down and shake like crazy at about 25 MPH. The problem would go away if I slowed down or increased speed to about 35 MPH. Also, would clear up if I lightly depressed the brake pedal, indicating that perhaps the TC was locking up just after the shift at 24-25 MPH. As far as I could tell, as soon as it shifted to third gear, the TC locked and bogged every thing down. Not wanting to chance failing the smog test, I cancelled the test.
As I recall, I had the same problem 2 years ago during the last smog test. The tech pulled it down to second gear and completed the 25 MPH portion of the test. The car passed then but the numbers for NO (PPM) were very high.
I have used this TT emissions chip since 2006 and passed with flying colors until the last time.The only changes made were that the torque converter was changed out shortly before the last smog test and the transmission front pump was overhauled by a local transmission shop with GN experience (Donnie Wang at DRW Transmission in Santee.
The car runs fine with it's TT alcohol chip installed but throws a fit with the emissions chip. Anyone ever had this experience or any insight into what is causing the problem with the transmission?
