williamsGN
'Horse sneeze' addict
- Sep 20, 2007
No luck in the transmission section, so I'll give it a try here.
I recently started getting this noise on first start up of the car. First noise is when I shift from P to R, then the second is when I shift from N to D. Doesn't make any noise after driving even a short distance and makes no noise on the road. Fluid is full and clean/unburned.
The trans is a 200, rebuilt about 1700 mi ago, the TC is an AC 9.5 2800 LU, rebuilt about 3500 miles ago.
Awhile back the LU stopped working and it is an internal problem since the solenoid was tested and replaced and the ECM is sending the LU signal. There is a definite delay going into gear while the noise is happening, after the car is warm, it shifts into gear right away without noise. Thanks
