My transmission occasionally won’t shift into 3rd gear at WOT. It happened one time last year, then again once last night. It has only happened twice in over 100 passes. Once I lift the throttle it shifts. The transmission is a stock 2004r with a B&M shift kit. I haven’t adjusted the throttle valve cable in a while. Is it possible the cable has stretched? Or could it be the P/R valve is hanging up? Any other ideas of what may be causing this?
Thanks,
Don
Thanks,
Don
