What would cause the tranny to leak quite a bit of oil between the front pump and Convertor?
Changed the seal on the pump, the one in there was not that old either and looked good, with no tears or abnormal feel to it. But replaced it still just in case. Also carefully inspected the snout on the Convertor, it looked fine with no scratches or cracks, the welds on it looked fine too. Still leaks, there is a stream of oil that appears to be running down in the middle under the snout of the Convertor.
Plan is to check the pressures on the tranny now and see if it is building too much pressure and causing it to push fluid past the front seal.
Open to suggestions and ideas.
Thanks,
Shev
Thanks,
Shev
