DAILYFLOGGER
I'm crushing your head !!
- Jul 22, 2001
Guys, I was guilty of jacking this other thread. But it seemed apparent that there was some interest in this concept--Open trailer, when the trailer brake and turn signal lights of the trailer come on, the Regal's stop and turn lights come on as well. Large and at a real good height.
In my initial research I have learned:
Thoughts?
Diodes are recommended to avoid having the voltage from the towing vehicle feeding back into the cars electrical system if someone should happen to step on the brakes while still plugged in. A diode block BX8863 from Blue Ox can protect both systems. The members suggestion of creating a plugin patch cord from a piece of trunk wiring harness also solves this issue.
I've been told that the factory wiring on my '99 Tahoe is marginal to be supporting lots of lighting load-could burn up the trucks parking light circuit especially. I'm considering a Modulite to deal with this concern. For those that have never setup their tow vehicle, you might need a module to convert your separate brake/amber turn to a shared brake/turn signal for the trailer.
I think it would be better contrast to leave the Regal's running lights off. Brake and turn only.
Thoughts?
