TR Miscellaneous Parts, TR Hood, Fuel Pump, Torque Converter,Valve Covers....
Silverttype1
Below TR Parts for sale...SHIPPING PRICE NOT INCLUDED
Used Powermaster Brake Accumaltor Ball $100.00
Stock crankshaft -- no nicks, never turned, Journals OK, needs cleaning $100.00
Poston driver side exhaust header "no cracks" (if purchased separately from stock exhaust system)$100.00
or purchased with with stock passenger side header, along with crossover pipe and exhaust "Y" pipe all for$200.00
FullThrottle High Volume Front Cover (Spot faced) $100.00
RJC Billet Aluminum Power Steering Pump Pulley $65.00
Stock Valve Covers $50.00
Drive shaft loop $20.00
Stock Flexplate $20.00
Aftermarket stock replacement MAF pipe $10.00
86 Buick Front Grille (needs TLC, chrome overlay lifting off) $75.00
Stock Air Filter Canister $15.00
Stock Fuel Pump Essembly $40.00
(2) Bosch #233 NON adjustable fuel regulators both for $25.00
Stock turbo inlet adapter with (2) breathers and hose $20.00
Crank Sensor and support bracket $20.00
ARP 12 point head bolt kit - Summit Part # 223-3703 $55.00
Stock Vacuum Block $10.00
Stock Fuel Rail $60.00
Turbo Oil Drain Line $50.00
Stock Alternator Pulley $10.00
12" Torque Converter--Ran consistent 11.50's @ 122MPH (small turbo) TE-45 using this converter $100.00
Stock Heads -- Heads only no valves or springs, Heads Need truing and cleaned $50.00
(6) Stock Connecting Rods $50.00
Stock Electric Fan $50.00
Stock Water Pump Pulley and Harmonic Balancer…make offer??
Stock EGR Valve Cover $5.00
Stock Oil Filer Neck..has crack on top cover $10.00
Stock Turbo Hood (NO dings) with Buick Turbocharged "6" Logo Insulation Pad--cannot ship $300.00
Stock Power Master Brake Assemby/comes with Grey Pressure Switch…PUMP MOTOR Is Seized $100.00
Taylor Trunk Mounted Aluminun Battery Box/ comes with (2) 15ft 2GA Cables $100.00
Used VDO 30lb Boost gauge--fits standard A pillar Buick TR gauge holder $25.00
I can send individual pics upon requests.
interested in the torque converter. details, condition, milage, pics? Thanks
I'm interested in connecting rods. Do you have stock wrist pins? Also Powermaster.
Fuel pump and driveshaft loop pics and condition please
Pic attached on stock fuel pump assembly and drive shaft loop...FYI: Instro84 was first to inquire on driveshaft loop, if he passes your next in line if still interested. :)
Fuel pump is 307 Walbro
Thanks for inquiring.
Jeff
dand
Pics attached.
Torque converter info Part Number 8653420 CBCF; approiximate stall at zero boost on my setup was on/about 2200-2300RPM. Condition you ask, converter performed flawless when removed; upgraded to Vigilante 9.5" non-locked. Amount of miles...on about 2000--with about 50 successful 1/4 mile passes.
Thanks for your interest.
Ttype6,
Unfortunately no on the wrist pins...otherwise rods are in great condition. I have attached pics on rods and powermaster.
Jeff silverttype@cfl.rr.com
