just installed a new tps on the throttle body what should the correct reading be with the key in the on position so its set correctly ? on speed pro.Thanx
GM factory is .45 - .55v. FAST is where ever you want it, kinda sorta, alot of people have them @ about 12%. But the factory setting is a good start. You want 4.5 - 5.0v wide open throttle with 5volts being 100%
