Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
I come across some drivability issues with the car and the new FAST system. I have figured out the problem, now I need to know the cause to keep from happening again. I went from having a calibrated TPS to a 100% TPS reading with the touch of the pedal.
One of two things caused me to lose calibration.
1. I added a voltage booster between the install of the FAST
2. I disconnected the battery
So based on your experience is disconnecting the batt cause you to lose calib, or is it the addition of the VB that caused the loss of calib?
