my85grandnation
85 Triple Threat
- Mar 12, 2004
I was just checking to see if anyone had ever tried the 86-87 TPS unit on the 84-85 cars? Reason being is they look identical but the parts stores want $209 for the 84-85 sensor and only like $40 for the 86-87 sensor. I figure as long as you can get your idle and wot readings correct you could use the 86-87 sensor but was just wanting to confirm before I went that route.
