wickedmotorhead
SQWURLY
- Jul 5, 2004
I am still having false knock problems and I saw that torque convertor bolts that are loose could be the cause. I have put better gas in, but I only get knock when in second gear and getting on the gas even with NO boost. I have checked for anything loose...dipstick, DP, Crossover pipe, flexplate bolts, everything in the engine compartment, motor mounts, you name it. I am going to get a new knock sensor and line it with teflon next. I also wanted to check the torque convertor, but I have never had an auto trans is this easy to do. Do I have to disassemble anything? Thanks.
