Torque converter value?
N2BUICK
169
2
18
68
Del City,Okla.
Visit site
I have several converters collecting dust and need some help with direction on what to do with them. One with the least information is what i would like to ID first. I know no one can tell a stall speed range unless you can go back to the builder, or put it in a car and test it.
The case is only marked with PPP 2142 , the largest outside dimension is 11" , but the case is only 3.4" "thick". The hub and pilot are PG,th350,400 as i can tell.
I know this is a performance converter and has value but cannot tell anyone any spec other than physical dimensions. When is a converter a good candidate for someone to use or have re stalled? Or when is a not worth the freight or cost of opening up?
Thanks N2BUICK
Top Bottom
