Hello Buick Members,
I need your help.
I have an 87; GN with 34,000 miles. 8,000 of those miles have been put on in the past 3 years. Prior, this car sat for 10 years with minimal mileage put onto the vehicle.
I have followed the spring cleaning guide from the gnttype website. However, last night was the first time I performed the top engine cleaning described on that site; the cleaning were GM toe engine cleaner is put in through the intake and creates significant white smoke as carbon is removed.
However, upon completion, I went for a drive to clear out the system and had bad results. The car would studder, excellerate, knock (per scan master), pull hard, bog down, etc. I could excellerate under 3/4 throttle once, then next time the engine would break up under minimal throttle; I could barerly get the car going from a stop. While driving, it kept studering, other times it would pull ok.
Over the next hour+, I reset the computer 3 times, checked to make sure the MAF was re-plugged in correctly, and also verified that the air inlet tube from the intercooler was sealed. These were things I read as problems from other posts that had done this service.
I also noticed that, at times, my O2's were stable around 500-700. It would run with O2's remaing at 550 for 20 seconds. Prior, I remember the O2's fluctuating much more. A few times during driving, the O2's would not drop below 600 no matter the throttle position or fuel and spark adjustments I would make through the Scan Master.
Any advise on what to check next would be appreciated.
Thanks!
Matt
I need your help.
Thanks!
Matt
