Top end studder under boost. Iac is 43 and it will not go lower. Blm 136 at idle warmed up, no vaccum leaks found. 15lbs vaccum at idle. Running TT chip and 45 lbs fuel pressire line off. It was fine until I laid into with a 1/4 tank of gas. It studdered like lack of fuel so I let off. I filled it up and it studders on top end under boost once out of every 3 times. Currently running open dump with 26lbs of boost. Has run 30lbs previouly but I turned it down.
Thanks for the help.
