I have been thinking (maybe overthinking?) about a few things.
I just bought my first set of slicks, they can be run without tubes but tubes are recommended. Hmmmm? So...what is the difference? Does the tire react differently with or without a tube? I would think that with a tube at low air pressure the wheel would have less tendency to spin on the tire bead. Is it just a safety issue or is there a technological advantage or disadvantage with or without a tube?
What about total rollout? Without a tube I would think rollout would be easier to equalize. Having the air pushing directly on the tire, instead of the pressure from the tube.
How important is rollout and how do you figure it out as the temps change, air pressure is adjusted for track conditions, etc?
I mounted my new slicks (without tubes) and at 15PSI they are 1-1/2" different in total circumference at ambient temp. I am really disappointed with such a large difference. I'm not sure what to do as I'm thinking the stress this could cause on my differential, axles and if the car will launch straight? Maybe I'm overthinking? But that's why I'm on here asking.
Thanks in advance for any comments, Bill Brooks
