Timing in chip is 20* and all of my monitors are reading 28*. I tried 3 diff chips and 3 diff monitors/scanmaster and they are all showing me that the timing is 8 degrees off exactly every time. Example if i put a chip in that is supposed to be 20* at WOT the monitor will read 28* and if i put a chip in that is 25* timing on the monitor is 33* This issue is also causing a lean condition. Car idles, runs, and drives fine but is lean at WOT and i am seeing a little knock. I tried all the basics and nothing changes it. BLM's, O2, and MAF are all where they are supposed to be too.
Anyone else ever had this issue? Any input?
