Let's look at my Stage II example with the drag sim. We'll pick out two different shift points. One example will use a 9,000 rpm shift point for both shifts. The other will use a 7,250 rpm shift point for both shifts.
Included in these new graphs will be the amount of torque converter multiplication we have throughout the run, a good indicator as to whether we have vortex or rotary flow in the torque converter, and we'll also include the amount of TC slip.
Vortex flow is strongest when the speed difference between the input into the torque converter (engine rpm) and the output from the torque converter (trans input shaft) is greatest. As the difference in speeds come to more closely match, you gradually move from vortex flow to rotary flow. When you have a rotary flow condition, that is when the TC is considered to be coupled.
Vortex flow will give varying amounts of torque multiplication, depending on the speeds of the input and output of the torque converter and the difference between the two. The greatest torque multiplication, and vortex flow occurring when the engine is at the stall speed of the torque converter and the speed of the output of the torque converter, the transmission input shaft, is at zero.
Rotary flow will give you no torque multiplication. The rpm speeds of the input and output of the torque converter are very close to the same when you have rotary flow. Rotary flow is characterized by low TC slip rates.
A TC can be considered to be coupled at slips rates as high as 15% at high engine rpm.
