Throttle cable
RED LS1
SENIOR MEMBER
What are some of you guys doing about your throttle cable? Is it difficult to remove the factory Buick one? I see Lokar makes the LS aftermarket one. Does it work okay?
I used the elect servo unit, no cable, works perfect, used the truck pedal,
Thanks. If I'm going to be in there changing the pedal around I'd just assume swap the cable out. I just bought a new cable TB for it too.
