Hi guys, the first post on a very long time for me... I have now got the car running at idle, but it hesitates when I push the gas and want to die and in some cases dies. I replaced the IAC last summer, it went better but I have not driving the car on 2-3 years due to problems that I havent been able to solve. I also replaced the EGR valve, and the car idled a bit better after that.
I wonder where the throttle blad adjustment screw are located ? If you stand on the driver side and look at the throttle body, is it the one that is on the right side of the "throttle arm". At least I found a screw that the throttle arm is "resting on" wich was proctected by a grey rubber thing...
Daniel
Daniel
