I just got my thrasher 92 chips in the mail. (92-28-K2.0) , ( 92-30k2t.0) and my 100-30 chip.
When I pluged in the 92-28-K2.0- They car started and idled much better than the original Factory chip. (Ibought my 86 GN new in 1986 so I know that the chip is original). As soon as I started to drive away the engine felt way down on power and if I tried to put my foot in it at all, it would start to cough and pop out the intake, and I could not get over 5-10lbs of boost with out 12- 20 KR on my Scanmaster II. I tried the 92-30K2T.0 and it was even woorse, same symptoms. (I am not posting to knock the product, it is common knowledge that Thrasher chips are great).
I plugged up the stock chip and get 14lbs of boost in 1st with 0.0 KRs.
Here is my setup:
1986 GN engine bone stock 130,000.
Stock Trans and stock Posi rear.
Did complete Spring cleaning.
Red Armsrong FP and Billet adj FPR
Hot wire Kit
All new I/C hoses and clamps
ATR 3" DP and 3" dual SS exhaust
ATR 14" Cold air kit
160 deg TS
All new vacum lines
New coil pak and new ignition Module
New 8MM plug wires and autolite plugs
Fuel pressue set to 45 lbs at idle with vacum off
02 reading after 1/8 mile (back road) stock chip "849" 0.0 KR
02 readings were real strange with either Thasher "028" 15.3 KR
"039" 20.3 KR
Couldn't get much over 35 MPH had to let off.
I had FP guage hooked up on all runs and pressue rose just fine with boost.
I put the stock chip back and it runs like just fine. Any ideas anyone. I emailed Scott for some advise also, but was hoping someone might have some insight over what I am missing here?
I am running 10gallons of 93 Octane with 16oz of 104+ racing octanne booster. I haven't tried the 100 Thrasher yet.
Here is my setup:
Hot wire Kit
160 deg TS
All new vacum lines
"039" 20.3 KR
