usetaboost
SAY CAR RAMROD!!
- May 4, 2005
I've went through a lot of threads already but it seems there's always a few details missing to questions I have. To start off with I have 5658s and 5413 springs and bilstein shocks. Everything else is stock replacement, nothing fancy. As of now the car rides and handles good imo. One thing I've always noticed is the front seems a little high, especially after going to 17 in wheels and even running a 245/45 tire. Even with the stock size front tire it always seemed like it could go down a bit more with no ill effects. Rolled with Jdpolzin on the power tour and he thought the 1 inch (taller) lower ball joint would do the trick, but said the front tire may rub after swapping the lower ball joint. With all being said, is anyone running this setup with the 245/45 tire?
Another issue I have is with running the 275/40 tire on the back with the 9.5 wheel. As of now there is no rubbing but I'd really like to go with a 285/40 tire. The wheel seems to have the correct offset. I currently have aluminum drums on the rear. Can I get this tire to fit by running a cast drum to bring the wheel in just slightly and not have an issue? I know all cars are different with body and rear spacing. Just trying to get other's opinions on this. I've seen this rear tire used on a monte ss with the same wheel setup I have and it looks perfect. Imo the 275/40 is just too damn short and looks almost ricey.
Thoughts? Concerns? Feelings?
