The TE-44 turbo should spool almost instantly. Your tune-up is probably off a bit if the spool-up is slow. Have you checked the Racegate valve for leakage? I just replaced my Deltagate because it wouldn't seal, and leaked BAD! If you have a Racegate in the cross-over pipe, the pipe cracks easily around the welds. What have you done with the stock wastegate 'flapper'? If the flapper isn't held closed with a STRONG spring or an adjustable actuator, then it'll leak and cause slow boost. Was the turbo purchased new or used? If the wastegate port was opened up for a THDP, the the stock flapper on the stock elbow will NOT cover the whole port opening and cause real slow boost curve. The adjustable air regulator for boost control works, but they will cause a slow boost curve because the wastegate will start opening around 10-12 psi (sometimes sooner depending on spring pressure in the wastegate) They work off of pressure differential (deltaP) and start passing air early, causing the wastegate to start moving very early. An electronic 'gate controller will keep the 'gate closed usually untill you reach 80% of target boost. Just some things to think about.
