Yea sorry,i subscribed to the thread because I have a similar problem in one of my cars and I wanna see how the problem plays out...I'm sorry, I take it that you are asking me to subscribe to the site?
I was told to post on this forum by the corvette forum as you guys over hear are helpful.
I've only posted one thread and it seems I've outstayed my welcome already as an unpaid member.
Thanks to all the guys who took the time and posted constructively it was appreciated.
Would a failing 2nd gear band effect/cause low 1st gear pressure, as I'm not sure how these things work and just need to get my head round it.
Or would the low pressure cause the band not to grip properly?
P.S.
Under CRUISE throttle I will be in 4th at 45-50mph and if I hit the throttle half way down it will jump down to 1st, whereas before the problem it would only drop down to 2nd or 3rd depending on the throttle position, but above 50 it will perform normally.
No it won't shift from 1st - 2nd at any rpm under firm full throttle! So it looks like the band as you said!
When we first installed the trans it had pressures of about 240psi at full tv but I guess over the last 5 years and 15,000 miles it must of deteriorated.
The pressure at idle with TV pulled fully out was about 225psi ! Could it loose pressure through the system to only have 190psi when in drive?
Peter
