Black,lower the price a little and I'm all over it....
The one I offer is cheaper than both unless ordered with Garrett housing but the sealing rings and thrust assembly is the best I can get my hands on. I take a hit on margin using these parts but id rather be more competitive. I've taken apart some new/nearly new turbos just to replace those parts. I've fixed several high dollar turbos that smoked like a coal rolling diesel by simply replacing the ex side piston ring and de-carbonizing the shaft. Other times I've found that the oil return was inadequate when the owner thought the turbo was shot. I've also found a couple that had shafts that were apparently re-ground and balancing as an assembly was impossible. No matter what you use or spend on the unit things still can slip through the cracks. That's where the vendor needs to make a decision to good will it or not. Even when it's very apparent that the failure wasnt due to manufacturer defect it's still worth eating it more often than not. On another note let's let the OP sell his turbo. Starting a new thread at this point would probably be the right thing to do. He can ask any amount he wants. Anyone can make any offer they want.chriss4655 said:Those budget turbo are just that!! BUDGET !!!! I bought one from full throttle and it lasted 2500 easy street miles then started to leak oil on the hotside! Of course the car isn't a DD so it was passed the year warrenty. The moral of the story is u get what u pay for. I'am sure the one from Limit would be far better quality.
Turbo is sold.Thanks Bison.paypal sent
