Mountain GN
No, it doesn't have a V8.
- Apr 19, 2006
Up for sale is one TE44 turbo. Hot side is a A/R .63 Garrett housing while the polished compressor is a .60. Wastegate hole was ported to about 1.25" before I bought it, and it spooled up FAST. This unit has about 23,000 miles on it, has perfect fins on both sides, and has no up/down shaft play when oiled up, and a very tiny amount when dry, which is often the case. Has absolutely no in/out shaft play at all. Doesn't smoke at all and has minimal oil seepage. I had a turbo saver on this for all but the first 3000 miles of use, so the bearings are good. I will include the adjustable actuator in the pictures, but I suspect that it may be bad, as it didn't like to build boost much past 15 PSI until I replaced it with a fresh one.
I'm selling because I went bigger and got a converter. Runs good and doesn't need a rebuild.
$400 plus shipping. Total packed weight is 21 lbs and my zip is 93225.
