Ok, my buddy had this TE44 turbo on his GN. After awhile, just at idle, it would puff white smoke out the tail pipes. Since then, he has had a bunch of work done to the car and has upgraded to a CPT-65 turbo and he still gets a small puff of smoke out the tail pipes. We're thinking it has something to do with the PVC issues.
Anyway...the TE-44 sat in a plastic bag for a little over a year. The shaft spins, there is no play and I believe it only has 2000-5000 miles on the turbo, MAX. Externally it looks perfect, but when spinning the shaft it kind of "catches" here and there, nothing big. Just wondering if that is because it's not being oiled and it's not a BB turbo.
I did plan on rebuilding it. It is also externally balanced, so I have a local shop that will take care of that for me.
Should I bolt it up and see how it does, or be on thesafe side and rebuild it?
Many thanks!
Many thanks!
