I bought a new normally open pressure switch and put it in the trans during rebuild, but didn't replace the lock up solenoid. Well I should have known better, the solenoid was bad and had lock up constantly. I bought a new solenoid locally from Advance BWD brand S9811 and installed it, it popped the fuse initially that I had piggy backed into, so I replaced it and drove it again. Converter didn't lock up in 4th like planned. I found the pressure switch got smoked too. I tested the new solenoid and found it draws 17 amps, pretty sure that's way too much. I'm going to return it and get another one, but I cant find a n.o. pressure switch locally. Does anyone know which parts chain might have it and how it's listed?
