vicious6
Turbo Regal Obsessed
- Nov 26, 2001
Dear Sir:
This letter is in response to your recent letter requesting a
more detailed explanation concerning my recent internment at
Methodist Hospital.
Specifically, you asked for an expansion in reference to Block
21(a)(3) of the claim form (reason for hospital visit). On the
original form, I put "Stupidity".
I realize now that this answer was somewhat vague and so I will
attempt to more fully explain the circumstances leading up to my
hospitalization.
I had needed to use the restroom and had just finished a quick
bite to eat at the local burger joint. I entered the bathroom,
took care of my business, and just prior to the moment in which
I had planned to raise my trousers, the locked case that
prevents theft of the toilet paper in such places came undone
and, feeling it striking my knee, unthinkingly, I immediately,
and with unnecessary force, returned the lid back to its normal
position.
Unfortunately, as I did this I also turned and certain parts of
my body, which were still exposed, were trapped between the
device's lid and its main body.
Feeling such intense and immediate pain caused me to jump back.
It quickly came to my attention that, when one's privates are
firmly attached to an unmovable object, it is not a good idea to
jump in the opposite direction.
Upon recovering some of my senses, I attempted to reopen the
lid. However, my slamming of it had been sufficient to allow
the locking mechanism to engage.
I then proceeded to get a hold on my pants and subsequently
removed my keys from them. I intended to try to force the lock
of the device open with one of my keys; thus extracting myself.
Unfortunately, when I attempted this, my key broke in the lock.
Embarrassment of someone seeing me in this unique position
became a minor concern, and I began to call for help in as much
of a calm and rational manner as I could.
An employee from the restaurant quickly arrived and decided that
this was a problem requiring the attention of the store manager.
Betty, the manager, came quickly. She attempted to unlock the
device with her keys. Since I had broken my key off in the
device, she could not get her key in.
Seeing no other solution, she called the EMS (as indicated on
your form in block 21(b)(1)).
After approximately 15 minutes, the EMS arrived, along with two
police officers, a fire-rescue squad, and the channel 4 "On-the-
Spot" news team. The guys from the fire department quickly took
charge as this was obviously a rescue operation.
The senior member of the team discovered that the device was
attached with bolts to the cement wall that could only be
reached once the device was unlocked. His discovery was by
means of tearing apart the device located in the
stall next to the one that I was in. (Since the value of the
property destroyed in his examination was less than $50 (my
deductible) I did not include it in my claim.)
His partner, who seemed like an intelligent fellow at the time,
came up with the idea of cutting the device from the wall with
the propane torch that was in the rescue truck.
The fireman went to his truck, retrieved the torch, and
commenced to attempt to cut the device from the wall. Had I
been in a state to think of such things, I might have realized
that in cutting the device from the wall several things would
also inevitably happen.
First, the air inside of the device would quickly heat up,
causing items inside the device to suffer the same effects that
are normally achieved by placing things in an oven.
Second, the metal in the device is a good conductor of heat
causing items that are in contact with the device to react as if
thrown into a hot skillet.
And, third, molten metal would shower the inside of the device
as the torch cut through.
The one bright note of the propane torch was that it did manage
to cut, in the brief time that I allowed them to use it, a hole
big enough for a small pry bar to be placed inside of the
device.
The EMS team then loaded me, along with the device, into the
waiting ambulance as stated on your form.
Due the small area of your block 21(a)(3), I was unable to give
a full explanation of these events, and thus used the word which
I thought best described my actions that led to my
hospitalization.
Sincerely,
S. Anderson
Methodist Hospital.
hospitalization.
position.
device.
hospitalization.
Sincerely,
S. Anderson
