lotzagoodstuff
lotzagoodstuff
- Dec 19, 2009
Car is totally stock with exception of K&N 8 inch filter and both valve cover breathers replaced. I have a new tuneup (plugs, wires, pcv, fluids) and I just installed the K&N this weekend. Seemed to run ok until this evening. I did notice after removing the factory air cleaner hardware that I no longer had the "turbo power" lights on the dash, but honestly I can't remember if they worked before removing the stock air cleaner.
Car really feels like it's starving for fuel, and I will do a driveability test with fuel pressure gage tomorrow, but at idle its 30ish psi and jumps up when free revving (I know I need to do a dynamic test). Car revs fine in park, I have checked all the hoses and ducting for leaks. Going to try to test fuel pressure while driving, coil pack and maybe MAF sensor tomorrow.
No codes, no popping, just stumbles like somebody is shutting fuel or ignition off as soon as I apply any throttle under load.
Any help is appreciated, sorry I don't have a scan tool and/or more information.
