I have a FAST problem That just surfaced. I don't own a GN but have been on the board for a while. The vehicle is a 93 Typhoon that is heavy modded. Bowtie block, billet crank, Flowtech ported heads, Pontiac intake with Wilson (ford type 75mm TB), 72GTQ turbo, 75# injectors, Digital 7 MSD, Race prepped fuel system, etc.
Truck runs 11.1s at 124 mph...
Problem....(just occured out of nowhere after three years of no trouble)
Under laod/boost the pulse width shuts down at 5,200 rpm no matter what gear it is in. Even in third I can run 23lb boost with everything fine till 5,200 rpm. It does not drop cyclinders like a rev limiter situtation, just fuel cut off .... but not completely.
Things that I did so far since trying to figure this out....
-Changed out double pumper for large external fuel system.
-unhooked 7 series MSD
-isolated boost controller
-change out TPS sensor (voltage is correct)
-timing is same (crank to computer)
-Changed out ingition module
-changed out 3 bar map sensor
-checked out wiring harness for grounds, etc
-checked alternator (14.4 volts)
-put in several older programs that didn't have this problem
-FAST sent me the a new box with 1.05 software
Things noticed.....
-When setting the rev limiter lower than 5,200, cyclinders drop as expected so I know the rev limiter works as normal.
-In park/netural (no load) the motor revs fine through 6,000rpms and above
-under load with little or no boost (5-8lbs) revs fine through 6,000 or higher.
- At 8-23lbs boost(or above)... shuts down, but not off, at 5,200 rpms
-tps still at wot (92%)when this happens
-timing stays according to table (24 to 26*)
- fuel pressure and boost fall back accordingly as pulse width drops
-data log shows that injector pulse width just drops (always at 5,200...no matter what gear)
-if I keep the pedal to the floor (wot and full TPS) it still runs smooth (at lower rpms), but fuel and boost are cut back and no power.
-if I let off pedal for just a second it resets and fuel and boost comes back...till it hits 5,200 again.
The new box and the old box act the same. Old box was tried in friend truck just fine.
I have had Speedpro/FAST for over three years with great success and (although not professing to be an expert), I have a good sense of the program. I have tuned my truck and several other vehicles with no problems over the years. Tony at FAST, Dave Henninger at Hardcore Motorsports (Formerly of Wheel to Wheel), and others are trying to help figure this out. So far we haven't.
Any ideas would be very appreciative. Maybe someone here has had this type of problem. Hopfully it may be something simple...something that is so obvious it is just passed over as we may be making this to complicated.
List of Mods
Sorry about the long thread.
I am traveling on business till Tuesday. I can post a run then if needed.
Thanks to everyone in advance....
John
Things noticed.....
List of Mods
John
