shifter
by wobbles do you mean front to back, side to side, or both? i just had my console out to put a new stock shifter in. is the pin that holds the shift rod in loose or worn out? there is a hairpin style clip that holds the large pin in, if it were to somehow work loose that may make the shift rod wobble. also, is the shifter assembly still bolted to the floor with its four bolts? you will probably have to remove the console if you have not already, but the shifter handle would have to come off first
