Luckydog32
- Sep 28, 2014
Finally got my 86 GN running after tearing it down to do a mini restoration. Changed cam( comp cams 206/206), lifters, valve springs and timing chain gears. Reset both the cam sensor and TPS. The issue I’m having is that I have to pump throttle to get it to start. Kind of like an old carb. Once it starts and I get it to run for a few min it will idle but it idles high. I don’t have a tach but I would say about 1000-1500 rpm. It runs smooth and only a small bit of hesitation if I give it some gas. Car is basically stock except cam. I do not have a scan tool but I think I will order one this week.
