Turbo Loyd
- May 26, 2001
On two occasions our blue turbo Regal has stalled and would crank. but not start until the car cooled down a bit. It has been surging for awhile when driving at 45 mph for awhile, and now I'm wondering if it is related to this stalling.
On both occasions it has popped through the intake just before stalling. The first time it was only about two minutes before it restarted and ran fine. The second time I had to wait about a half hour before it would restart.
Usually thought once a crank sensor went bad, that was it, what else causes a no start occasionally on an otherwise good running car. The car has a stock computer with Turbo Tweak chip, stock module and coil pack, cam sensor set at stock setting. The only code that it has thrown is a 41 related to TPS which should not cause a no start problem. The SES light comes on under mild acceleration.
Have checked a majority of the grounds and connections, which are dry and tight. The fuel pressure according to the gage on the rail does not leave the base settings when the car stalls and does not restart. Neither time when stalled did I have my OTC 4000 monitor along to see what readings were there and/or not there.
Thanks for your ideas
