INTHEEIGHTS
My Dads Faster Than Yours
- Apr 15, 2004
Here is a list of parts ..
4.1 offcenter stage 2 engine block#25500016 I think the build date is C 21 5 all machined and ready to go, all ARP hardware perfect block.
1 set of champion stage 2 heads complete all new valves, enkal valves an retanners new springs all t&d roller rockers set up for these heads
1 complete set,(6) of JE pistons turbo 517 f , no rings .
1 scat crank. stroke 3.625 part #81199.1 casting #961
1 complete set of (6) recon cunningham rods http://www.cunninghamrods.com/
1 Sheet metal Hogan intake twin throttle bodys with 1 set of 160lbs injectors
1 set of moroso sheet metal valve covers .
1 ati fluild damp
1 sfi flywheel
1 stage 2 front dry sump cover new
1 set of roller lefters and push rods
1 lite weight billet roller timing chain set
1 msd billet alum disturbeter #8551
1 set of msd 8.8 wires
1 water pump and drive belt pulleys
1 buick delco starter, good
1 drive side HRPARTSNSTUFF motor mount.
will take $8600.00 for complete motor everything listed above.....
i also have the fast system and a innovative boost controller available seperate.
Needs cam shaft an bearings ready to assemble ..
For more info Please call Anytime 269-605-6548 Thanks Ken
Went to a BBC BIG turbo.......
Will post pics here in a little while ..
1 ati fluild damp
1 sfi flywheel
