selling my complete Stage 2 engine,It is fresh with 6 easy passes on it 153 on center block cross bolted front and rears
3.625 BMS Crank,Oliver Rods,Diamond pistons
RPE Spec Solid Roller,all brand new cam,timing setup,lifters,matched springs and pushrods.Danny Bee Cam retention setup.
Heads are Champion "R" heads just redone by RPE also,All new ARP Head studs,cometic head and intake gaskets
They have T&D Shaft mounted rockers(Not the cheap ones)Valve Covers are Champion RPE Racing Engines.
Intake is a BGC ported with RJC spacer 70mm Throttle body 160# injectors.Oil pan is a stock style made deep, baffled with external pickup and complete Duttweiler oil pump assembly with remote filter mount
BHJ Balancer,JW flexplate,Champion Non a/c bracket
Meziere electric water pump,HR Parts mounts
MSD Billet Distibutor with MSD Merritt black wires
Custom ATR 4 bolt headers
It is 100% assembled
16,000 firm
Can be heard running,Will bring running car to BG you can see it run,And ill pull it out if you buy.
Im going to play elsewhere,The crap in the Buick Community has just gotten to me.So this is the reason for selling.
16,000 firm
