to make a long story as short as possible. i posted about "lean out pop" a few weeks ago and thought i had i figured out with my fuel pressure dropping at WOT that i would need a new pump. i installed a walbro and hotwire kit. at the time i was doing this i installed a hotchkis TVS suspension system, a set of bilsteins, all new steering links as well as the pump and harness. (i also have new 60lb mototrons and a new TT 5.6 chip to put in) i didnt want to add to the variables before making sure the lean pop was gone, so i havent installed them yet.
i went to drive the car and it wouldn't boost over about 14lbs. sputterin and just soundin kinda crappy. i figured maybe i messed up some vacuum lines and so i replaced them all! also fixed my PCV hose which was kinked. the car then boosted around 25lbs!! and STILL POPPING OUT
Ok, so at this point i figure the PCV kink maybe was messin with the car and the previous owner turned up boost because of the line bein kinked so i adj. the wastegate back till i boosted around 20lbs. (it was around 19 before, and its still popping out. i also replaced the MAF with a stock style just to see if the K&N oil fouled it up. (just an idea, dont know if this happens to anyone or not). now i'm at a loss...... could it be coil?? plugs??? or should i proceed with the new injectors and chip???? i run about 4.5 gallons of 110 as a mix with the rest of the tank 93. anyone with ideas?
