I spoke with ARP in regards to a lot of us lifting the heads during a hard pass in hopes of somehow getting help finding a remedy. He suggested we try their stud line in upgraded material (2000 series I believe?) that has a higher strength with a torque spec in the 90lb range. Ive been texting back and forth with Allan (turbobitt) and Brian (bison) on this and we were discussing the occurrence of the head and deck deflection, which would negate any benefit of a stronger fastener. The person I spoke to at ARP didn't mention this, but he probably doesn't realize this to be an issue on our engines anyway. I am far from a "pro" on these things, so I figure I could get some input from you guys. This would obviously be a custom run of studs so pricing would have to be determined based on quanity. Either way id grab a set of these for myself if the general consensus is that it would be beneficial over the standard line of arp studs.
Thoughts?
Thoughts?
