strange problem, most of the time when the car is cold, the speedometer doesn't work. I'll drive it for 10-15 min (sometimes a bit more). the speedo will start working again. sometimes the car sets a code (need to pull it). at low speeds the needle is a bit jumpy until I get up to 35 or so most of the time when working.
the scanmaster does show zero mph when the speedo is out.
a few questions, this sounds like it might be the VSS, is that the sensor with the weatherpack 4 wire plug on the drivers side of the trans? I also noticed a regular looking speedometer cable.
can't find my service manual right now, it's packed away somewhere after moving!
tia for any advice.
tia for any advice.
