Well it's installed now! I also put in the SMC alcohol injection system. If you want to see some pictures go to Webshots.com and do a search for mrbuick101 and take a look. The install went sweet no real problems. The only body modifications needed was to cut about an inch of sheet metal where the tubes go through by the head lights. The kit was very complete and all parts needed were in the kit. The only thing I changed from the directions was to weld the Spearco bracket to the modified wastegate bracket. It took me two days (Sat. Sun) about 12 hours total. I could do it in half that time now that I know what to do, but I wanted to go slow and make sure I didn't screw anything up. All I can say is if you have been thinking of intercooling your 84-85 hot air car it really gives you a performance boost and is not hard to do. The only thing I would say is if your planning on radically modifing you engine with larger turbo, injectors, ported heads, cams, larger up and down pipes then go with the Postons kit. It has larger tubing to the intercooler, but if your close to stock like me the Spearco is great. Take a look and let me know what you think
