As far as the alcohol users here, what are you guys normally doing for plug changes? I'm a Mazda rotary owner that's using Razor's kit. I'm running a fairly heavy ratio of gasoline to alcohol (about 70/30) and am starting to experience what I think might be the spark blowing out at heavier loads (23+psi boost). Do you guys normally do anything as far as running a colder plug? The ignition system I use is very stout. I didn't have this slight hesitation problem several weeks ago when the weather is warmer but I am not and am not sure if it's related to the drop in ambient temps down from 80's to the 40's outside. I've been told that one possibility is spark is blowing out and that I ought to step the heat range of the plugs I'm using down one notch. You guys experience any of that?
B
B
