You'll get a lot of differing opinions here.
AC Delco CR43TS gapped at .035 under 20psi or CR42TS for higher boost, used to be popular until quality went down hill. Now days Autolite 24's (23's if running higher than 20psi) or NGK UR-5's gets a lot of votes. .035 gap is common. At higher boost some tighten the gap to prevent blowing out the spark. I don't use AC Delco anymore due to the inferior quality but I've used Autolite and NGK with no discerning differences between the two performance wise, at least on my setup.
