Stock Intake powder coated silver. The bad, previous owner used a sheet metal screw to hold the adapter in(as seen in pic) guess you could useepoxy to seal it up. Also the oil return is drilled out to accept a #10 an bulk head, I did this and used -10 hose and never had a leak( unlike the stock setup).
$50 obo plus shipping.
Stock up pipe, little bit of surface rust but otherwise perfect. $25 obo plus shipping
Also have a stock bare throttle body, has no IAC and the stock vac. block is broken Hasbracket for the cables still on it. And a stock pass. side header no cracks but its been welded at some point. Pics avaible.
Make an offer on both of these, I dont know what they're worth if anything.
