jburnsinnj
- Jan 4, 2006
I have a stock 87 G/N and have a problem breaking the rear tires loose on launch. (They DO NOT break loose) I recall this car having a lot more power off the line when it was new (has 34K now) and had trouble getting traction off the line then.
The transmission is not slipping and after a second or two the car accelerates normally and shifts good but is just slow for the first second or two. I cannot understand why it is doing this now.
I am running Goodyear Eagle's with stock tread and width, stock boost and the original chip. The only things I have changed are adding a F/P hotwire kit and Walbro F/P with an adjustable regulator.
The car starts, drives and performs flawlessly around town and at highway speeds but just seems slower than normal off the line. I would like to keep it stock without any more power adders and just get it to have more response off the line. Any suggestions to the problem would be appreciated.Thanks !
