Originally posted by Marc87GN
I agree 100% on the headers. I installed a tubular K -member and doing header gaskets was easy. I changed a head gasket on my GN and it was far from fun. If you have never done it, you are in for a treat the first time you do it. Doing cams would have been a nightmare, but I could run 10s on the stock cams all day and have 750 rpm idle.
I guess the problem is it's a pain working on a 17 year old car because things are much more fragile. On my GT, I never ran into stripped bolts, vacuum leaks, valve cover leaks or any of the silly things I ran into with the GN. By the time I had broke something, I had already seen 10s and several dozen 11 second passes.
wtf was so hard to to a headgasket on a gn? you gotta be kidding me dude, i have a hotair and there's a whole lot more to take off to pull the heads, and it was EASY...
