Check that all the bulbs are good, sockets are clean, and grounds at all the light sockets show a low resistance to the negative battery terminal. I believe the speed of the "blink" is determined by the current draw through the blinker. If you have a bad ground, or poor connection in the socket creating high resistance, the current flowing through the circut will be different from one side to the other, therefore changing the flasher rate.
