Robert Wilson
- May 26, 2001
Need help trying to solve slow/weak 1-2 shift. I can also feel a little slip or chatter as band is applying that seems to be worse with more throttle/ power. I have only tried minumum and part throttle due to fear of burning up band.
Transmission was worked on by a general transmission repair shop prior to me workin on it and from the parts list, it has an Art Carr shift kit and .500 boost valve. PR valve and spring appeared stock. Drum and stock band was scorched when I recieved the car.
I installed good used drum, carbon band, and a sonnax servo. Band clearance is .110"
Hooked pressure gauge up saw the following readings:
min TV pressure @ 1000 RPM in Park, N, D is 70 psi.
max TV pressure @1000 RPM in Park and N is 210 psi
min TV pressure @ 1000 RPM L1, L2= 170 psi
TV pressure while driving would climb quickly of idle to 180psi at part throttle and only drops about 5-10psi on any shift.
Couldn't get a max TV pressure while driving as it was too hard to read the gauge and watch where I was going.
So far, I tried the servo with and without cushion spring with no change.
Tried blocking 1-2 accumulator with no change.
2-3 and 3-4 shifts are firm and quick.
Any suggestions?
Any suggestions?
