One thing I did forget to mention.......I just upgraded to a 70Q trim jb turbo.
I can launch w/ as much boost as I need.
(car has always been good about this) I have tried 5# to 15#, all on footbrake. I usally target 10#, seems to be the most consistent, but, yes, it always seems to spin as it leaves. Have played w/ tire pressure as well, found 12psi works best. I have air bags @ 10psi on DS and 15psi on PS
Other rear end pieces: ATR swaybar, CE lwr control arms (going to adjust those downward to change IC), snubber, 90/10's up front-50/50's out back, front swaybar removed
Things needing to be done: remove front bumper insert, move battery to trunk
What do you guys think? Is my set-up ok, so it must be tires?
TIA
