S Spooled85gn New Member Joined Jan 20, 2004 Nov 2, 2004 #1 I have a pair of 29x8.5x15 mounted on a pair of lightweight outlaw rims.. will they fit under the "black cars"
S Spooled85gn New Member Joined Jan 20, 2004 Nov 2, 2004 #3 nice, assuming the offset/backspacing is correct right?
W WIKEDV6 Well-Known Member Joined May 29, 2001 Nov 3, 2004 #4 Originally posted by Spooled85gn [B.. will they fit under the "black cars" [/B] Click to expand... You may have a problem if the car is "black", I had good lucks with blue, red and white cars. J/K whats up Mike, you should be fine as long as the off setting is correct. Prasad
S Spooled85gn New Member Joined Jan 20, 2004 Nov 3, 2004 #5 HA HA U A FUNNY MAN!! well you know my "primer" has turned a bit grey in the sun, so maybe they'll fit fine..
