juan_valdez_zz4
- May 6, 2003
I have an 87 Turbo-T Limited that is pretty much stock except for a CAI and a Hooker exhaust with no cat. I am slowly going to start adding some performance parts and I what to make sure I have the stock set-up tuned right and then I can go from there. Here are my readouts with the engine warmed up, idle and in gear
O2 - up and down .1-.8
AF-04
L8-32
BAT-13.2
INT-145
BL-160
CLT-170
ATS-126
R-675-700
TPS-.42
IAC-32
CC-138
All these number look ok, except for my BL which are high which would be lean. What range should I be shooting for? I was reading the "crazy 02s" thread and they were saying that this number is high because of a vacuum leak or exhaust leak pre-turbo. But I went for a drive and the BL go down to 128-130 cruising around and WOT. Also my O2s at WOT are .800-.820 with 2.0 deg knock on the shift and the cc is locked. This makes me believe that it is running a little rich. I just installed a new IAC and O2 sensor becasue the car was idling badly. It has improved now but I think it could be smoother. I am also going to be adding new plugs and wires soon. Are there any things that I need to check, change, etc to get the BL's down? Is it running rich or lean? I just want to make sure I don't go lean and hurt this low mileage motor. Thanks in advance !!!!!!!
Kyle
AF-04
L8-32
BAT-13.2
INT-145
BL-160
CLT-170
ATS-126
R-675-700
TPS-.42
IAC-32
CC-138
Kyle
